This has been going on alot with the Castle controllers. You may have to call them. You're running 6s2p right? You might want to get a himodel or two as a backup in the future.
Cat scratch fever build
I think with the castle link, the red wire has to be in the plug.Originally posted by bustitup View PostI had a rx battery pack plugged into rhe rx........the red wire unplugged on the esc
As far as the castle link....when plugged in now it recognizes the usb connection but not the esc......this has made me sickGovernment Moto:
Yes I plugged the red wire back in to use the castle link
Yes there is a whole thread over at RRR on plug in spark killing MANY HV 240's
Yes I own two himodel 200 amp 7s esc's for backup and a LV 240....should I try a himodel or hydra. 240 LV?
Originally posted by domwilson View PostThis has been going on alot with the Castle controllers. You may have to call them. You're running 6s2p right? You might want to get a himodel or two as a backup in the future.SPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
I would go with the himodel just so you won't run the risk of further disappointment. I'm tempted to get rid of my hydra 120's and going with some more himodels. This is getting ridiculous and I am wondering why castle hasn't issued a recall.Government Moto:
The HV240 need rx pack or Ubec. The ESC red wire must be plugged in the receiver (as it comes from Castle).Originally posted by bustitup View PostI had a rx battery pack plugged into rhe rx........the red wire unplugged on the esc
When I was searching what kind of resistance is required for the Hydras to eliminate the spark, I found out that it was recommended 1 Ω(ohm) 2-5 watt. Tested and no spark.
MGM recommends higher ohm but for the Hydras is 1Ω (if you put higher, it will not start).
I would sugget to bring the ESC behind (towards the transom) of the motor, in order to have the battery wires shorter. Finding the right position is quite difficult and all setups I've seen are different. Your COG should be around 32-35%, and your motor is a bit forward located.Last edited by DISAR; 08-29-2009, 04:33 AM.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
http://www.rcfastboats.com/
This is a false statement sirOriginally posted by DISAR View PostThe HV240 need rx pack or Ubec. The ESC red wire must be plugged in the receiver (as it comes from Castle)..
if you are using a rx pack or an external bec then the red wire on the esc MUST be disconected
BUT if you are using a castle link to program the esc then the red wire MUST be plugged back in
but thank you for the 1 ohm info i will make one of these anti spark cable set ups for sure when i get my hydra 240 back from CCSPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
Originally posted by domwilson View PostI can't wait to see videos of this puppy in the water...
me too dom....but here a video of it from the guy I bought it from...he ran it on 8s2p with a 1527 but a higher kv than mine....he smoked the hydra 240 on this run......after you see the two passes turn it off..the reat of the video is of him walking to get the boat dead in the water
she sure sounded sweet...kind of like she was mad at something
Originally posted by domwilson View PostAren't you the least bit tempted to throw that himodel in there just to see how she runs?
extremely tempted....and i probabley will...the hull hatch is not quite finished...I am in the process of sealing off the tunnel opening so I can stop water from getting in
few more daysSPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
Bustit I do not want to argue but my HV240 runs fine with the red wire Connected. You disconnect the red wire only if the ESC has a Bec circuit but you want to provide external power source. If the ESC does not have bec (like the Hydras HV series or the ETTI 2-7s) the red wire must stay connected.Originally posted by bustitup View PostThis is a false statement sir
Originally posted by DISAR View PostBustit I do not want to argue but my HV240 runs fine with the red wire Connected. You disconnect the red wire only if the ESC has a Bec circuit but you want to provide external power source. If the ESC does not have bec (like the Hydras HV series or the ETTI 2-7s) the red wire must stay connected.
Sir....... I stand corrected and you are absolutely correct the HV has no bec but the LV does
thanks for bringing it to my attentionSPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
So what's the point of running a Hydra? The specs changed, The warrantee changed, The quality changed and my confidence in their product has changed. The only thing that hasn't changed is the price.Government Moto:
So are those two 3S packs in series or two 6s packs in parallel?Peter Eells; Fun, and Helping others To Have Fun!!!
RC.Boats.by.Pete@gmail.com
