How to avoid "Sparks" when plug in lipo batt?
  • Tony
    • 420
    I'm using the 4mm gold plugs for 6S2P 5000mAh parallel set up. I'm getting sparks on the red + side connector of the lipo when plugging to the esc. Is there a way to prevent the sparks from happening ? Should i change to larger 5mm or 6mm gold connectors? BTW, The Turnigy lipos came preinstalled with 4mm gold connectors from Hobby King.
  • kookie_guy
    • 900
    you are gonna get arcing no matter what you change em to. I wouldn't worry about it. Just try to plug em in as quick as you can to minimize the arc.
    • Fastang347
      • Apr 2009
      • 100
      let us know how the batterys work out i just got 6 sets and have not had a chance to try them...
      and thier is a way to stop it not sure how but i did read it some where
      • simengj
        • 17
        Jep, just plug inn a resistance first, someone else can explain better..
        17 years old and Nitro/FE boater.
        • Comfortably Numb
          • 81
          plug in the + side first. and then the - so that you are dealing with the ground side of things.
          Do It in Vinyl !
          • egneg
            • 4759
            Here is a link ...
            IMPBA 20481S D-12
            • denboy01
              • 62
              No spark
              Maybe try the MGM speedo way, just click the link
              • Tony
                • 420
                http://mgm-compro.com/pdf/en-antispark-d230808.pdf
                Guys, thanks for responding.
                So, where can i find this Aux connector? will Radio Shack have it?
                • sailr
                  • 7128
                  You can just use small bullet connectors or a Deans plug, etc. There is no specific AUX plug.
                  Mini Cat Racing USA
                  www.minicatracingusa.com
