Small Block Chevy Engine 1/4 scale
  • Mikedm
    • Apr 2024
    • 17
    Is there anyone here that has the capability of making a true 1/4 scale small block chevy engine for me to use in a California Crackerbox, I bought the plans from Glen-L and will be sheeting the bottom today. Just planning ahead for myself, if there is please contact me so we workout the details.
    Thx, Mike
  • lohring
    • Jun 2011
    • 200
    I'd be glad to 3D print this model in 1/4 scale as a kit. I'd use white PLA+ so you can paint it whatever color you want. The cost would be around $10 plus shipping.
    Lohring Miller
    • Mikedm
      • Apr 2024
      • 17
      Lohring Miller
      Hello Lohring,
      The model you sent to me is very close to what I am looking for, but would prefer one with a single carb or dual carb and air filter, if you come across one of those it would be fantastic with me, your price is reasonable in my opinion. Let me know if you come across one.
      Thx, Mike
      • Mikedm
        • Apr 2024
        • 17
        Lohring,
        Here are a couple pics of what I would really like, found them on https://www.yeggi.com/q/small+block+chevy+engine/
        The first pic is my preferred choice.
        Mike
        painting#loaded error->painting#error" src="https://fbi.cults3d.com/uploaders/13427628/illustration-file/a9d459d3-9957-4a51-8bf1-357f516abf33/Tunnel-rammed-small-block-chevy001_03.png">
        • Mikedm
          • Apr 2024
          • 17
          Lohring,
          Mike
          • lohring
            • Jun 2011
            • 200
            The model I suggested has a single 4 barrel carb manifold. I can probably find a carb and scoop to add. The model you suggest would be more expensive, but would not be a problem to print. Again, it would be a kit requiring finishing.
            Lohring Miller
            • Mikedm
              • Apr 2024
              • 17
              Lohring Miller
              Hello Lohring,
              Could you give me a price for the first pic and also print it in aluminum color instead of white?
              Mike
              • lohring
                • Jun 2011
                • 200
                I have printed in Esun silver PLA+ and I would describe the color as grey, not silver. If you want a silver color I recommend Testors gloss metallic silver spray enamel over a white base. That's what I used for a Starship model. I printed a P38 in the Esun silver and it looks grey. I would charge $25 plus shipping for either color. Let me know.
                Lohring Miller
                • Mikedm
                  • Apr 2024
                  • 17
                  Lohring Miller
                  Lohring,
                  Sounds good to me, it would be 1/4 scale, correct? Is it made in multiple parts for me to assemble? Which is fine with me. How is the surface finish, fairly smooth or does it require surface finishing. Do you have a photo of an item that you have just finished?
                  Mike
                  • lohring
                    • Jun 2011
                    • 200
                    My plan is to provide a many part kit. That allows you to easily finish and paint the various parts. There will be layer lines. Paint will disguise them to some degree. A high build primer can fill them, but is not necessary in my opinion. Let me attach some pictures. The first give you an idea of what the layer lines look like close up. The P38 shows what Esun silver color looks like. Here are some pictures of real race engines. They are painted with some silver parts. Finally, there is a picture of a painted 3D printed Nautilus. The layer lines disappear at a distance.
                    Lohring Miller
                    • Mikedm
                      • Apr 2024
                      • 17
                      Lohring Miller
                      Hello Lohring,
                      Everything looks great to me, by what you say it will give me a chance to polish and paint the finished surfaces. Looks great. do you have the dimension info for a 1/4 scale chevy 350 v8? I found this info in a forum,
                      BLOCK (Bare)
                      L=21
                      H=12.25 (With main caps installed)
                      W=17
                      Height (Oil pan mating surface to top of block)=10
                      Deck width=7.75
                      Heads (Steel GM)
                      W=7.5
                      L=19.75
                      Height (outside)=5
                      Intake (Edelbrock aluminum performer)
                      W=9.75
                      L=20.75
                      H=4.25
                      HEI Dizzy with cap
                      H=7.75
                      D=5
                      Valve Cover (MT Aluminum Finned)
                      H=3.5
                      W=5
                      L=19.75
                      Oil Pan (Stock stamped)
                      L=21.75
                      W=9.25
                      Rear depth=7.5
                      Front depth=5
                      Rear step=8 from rear
                      Timing cover (Stock stamped)
                      H=11
                      W=8 (center)
                      Short tail TH350
                      L=27.5
                      W (Pan)=12
                      H=Height
                      W=Width
                      L=Length
                      D=Diameter
                      Now, the question is how do I pay you for everything, I don't use paypal or any of the other digital pay scenarios. If you will take a check, I will send one to you and you ship when it clears the bank or however you see it. I don't know if it's legal to post my email address in here or my mailing address. Let me know how to proceed and I will take action to get you your payment. Great work on those pics...
                      Thx, Mike
                      • lohring
                        • Jun 2011
                        • 200
                        The full size model I'm using measures 21.8 inches front to back compared to your 21 inches. I'll print it at 1/4 of that dimension in white (OK?) PLA+. I''ll PM you my address. Reply with your address so I can calculate the shipping.
                        Lohring Miller
                        • lohring
                          • Jun 2011
                          • 200
                          These are the first parts.
                          Lohring Miller
                          • Mikedm
                            • Apr 2024
                            • 17
                            Lohring Miller
                            This nice, looking forward to seeing the rest.
                            • lohring
                              • Jun 2011
                              • 200
                              Here we go. This is an exploded view with the parts in their approximate positions. I assembled the carbs on the manifold because the linkages and fuel lines are hard to figure out. Everything else fits as shown in the pictures.
                              Lohring Miller
                              Tunnel rammed small block chevy 0001_05.jpgP1010002.jpgTunnel rammed small block chevy 0001_06.jpgTunnel rammed small block chevy001_04.jpg
