Prop for power, not speed?
  • Diegoboy
    Administrator
    • Mar 2007
    • 7247
    I am building a contraption that is going to have very little surface area in the water, light, and big. It's my rescue contraption idea. Frame is built, just moving to it's power plant.
    What prop will give it power to push considering it's very light and high above the water?
    It's going to be brushed, 550 motor, 7.2V
    Thanks.
  • saleens7
    • 1108
    the prop from my high wind had almost no pitch and is large in diameter...its meant to be a surface prop, but using it as subsurface and it has a LOT of tourque...
    saleens7, the wookie of rc boating
    • Jeepers
      • May 2007
      • 1973
      a guy here built a custom rescue rig, It used a Integy lathe motor (rc rock crawlers use them) and turned a 447/3blade, this thing would pull just about any thing. make sure you have alot of rudder though, as this one ended up with a 6"x3" rudder so it would turn when bringin in another boat.
      • avengersteve
        • 321
        what size shaft are you going to use? i have the stock prop from my atlantic harbor if you wanted to try it on for size.
        restoring the collection
        • Diegoboy
          Administrator
          • Mar 2007
          • 7247
          It's a 3/16 prop shaft on a .130 flex cable
          • SJFE
            • 4735
            My next rescue rig is gona be outboard powered. Twins to be exact. I the maneuverability of thrust will make it a winner...Not to mention I'm gona use one of the 40 inch ebay cats...:D
            • saleens7
              • 1108
              let me guess....twin 820 ob's?
              • Doug Smock
                • 5264
                Thanks.
                Take a look at the Dumas three blade scale props.
                You don't want to use sub surface props on a submerged drive.
                Doug
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • Diegoboy
                  Administrator
                  • Mar 2007
                  • 7247
                  I took this question to my LHS, they recommended a
                  #3115 Bronze Propeller 3 Blade 1 3/4" Dia.
                  I bought it, do you think it's a good choice?
                  • saleens7
                    • 1108
                    probably, those are used in scale boats wich usually run low rpm motors, but they push out a LOT of tourque...i think that one is used in the Mr. Darby tug...they use two of those props on it and it has enough thrust to tug around a rowboat with two people in it...and its a heavy tug too.....some end up weighing 50 pounds...
                    • Doug Smock
                      • 5264
                      50 lbs is just the ballast. LOL
                      I think that is a good place to start Diegoboy. Check your motor temp, those props can be "adjusted".
                      Doug
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
