Kyosho Majesty 800 and 800s
  • royalcasa
    • Mar 2014
    • 560
    I have two complete kits the Majesty 800 and the Majesty 800s when did Kyosho stop making them
    Which one is more desirable, not sure if I want to sell them or build them. Maybe sell one and build the other one
  • Diegoboy
    • Mar 2007
    • 7444
    Here's some information...
    Originally posted by Stillwet View Post
    same boat, just as you mentioned above. the hatch you do not need a screwdriver on the S model. the S is just a newer version they even have a gas version S W / GT 16 41505. mine should be here shortly then i'll know more. brush-less for ease for me and yes that wood deck is a must.
    cut, trim, fit, sand, tape under side with Scotch tape, test for fitment, remove, put on wax paper use #2 oz fiber glass cloth on top and any 2 part epoxy i use West Systems is crystal clear, cover entire piece(s) let dry, trim glass edges, wet sand and one thin skim coat dry and or just use a matte finish sealer. i do not want mine to swell and crack and do not want to use teak oil too much maintenance, had out door teak furniture once.
    there are several glues to fit things to ABS so watch for that specific application (there's a lot of info just on that) i think i'll tack it with a compatible CA glue with a spread of an ABS/plastic 2 part epoxy there is a few. we can post info here i assume.
    as of a build thread i believe it goes else where here at OSE.
    So greatest of fun to you beetleman during your build.
    i have had my eye on a few of the Dumas kits and that TT Atlantic for awhile despite the ABS Hull i have always since i was young had a heart for Kyosho i own quite a few vehicles of there's and always enjoyed their models.
    ps i think the fly bridge seating and a couple of other details are slightly different.
    • royalcasa
      • Mar 2014
      • 560
      Thank you sir.
      By the way, I still have the 110 Coast Guard cutter. I bought from you years ago.
      • royalcasa
        • Mar 2014
        • 560
        Don?t know why pic is upside down
        • Diegoboy
          • Mar 2007
          • 7444
          Those are much harder to find these days
          • magnumb
            • May 2024
            • 2
            I would say the one with the handrails is more desirable. I think they started making these in 1985 and the S model was the newest version and only has one drive motor vs two.
            I'd send you money today via zelle or paypal for one or both of these:) I had this model as a kid and pretty cool to see them again.
            • magnumb
              • May 2024
              • 2
              $3500
