110' WWI Sub chaser.
  • 785boats
    Wet Track Racing
    • 3423
    Thanks for that Doug.
    I try my best.
    • 785boats
      Wet Track Racing
      • 3423
      Some of the restrictions have been lifted in our area, so we were allowed to travel up to 50k for picnics & outings while still maintaining social distancing protocols.
      So it was off to our local pond to test out this boat.
      The initial float test was perfectly on the waterline complete with a 6000mah 2s lipo in under the forward deck. A complete fluke.
      But that was without the superstructure installed.
      When the superstructure was added, the boat would not stay upright.
      So Jesse, your fears were well founded.
      So lead wheel weights were added along the keel inside the hull.
      That solved the problem, although it was still a little rocky from side to side.
      I added 3 1/2" lead sinkers on the keel in the middle of the boat.
      The boot topping line is now just under the water, but she is much more stable.
      I feel the 30mm 3 blade prop can be reduced to a 26mm prop as it only takes about 1/4 throttle to run her at full scale speed.
      I had 4 sessions of between 1/2-3/4 hour each on one 2s pack, & it still had 64% left in it.
      Of course, that was with general maneuvering, slow speed & medium speed running, docking etc, with a few high speed runs thrown in too.
      Bear in mind that the calculations showed, it only needs 11watts of power to reach the dynamic scale speed of 18 knots that the original boat was capable of doing.
      Here's a few pics of her at the pond.
        • 4340
        Good to see it on the water and I'm happy you were able to solve the balance issue so quickly.
        • 785boats
          Wet Track Racing
          • 3423
          Thanks.
          Yes, it was an easy task to add the weight.
          It was good to get out and about for a day.
          • hazegry
            • Jun 2010
            • 842
            Thanks.
            I might have missed it but what speed controller are you running I have just finished my hull, I need to wrap this one up so I can run it this year.
            • 785boats
              Wet Track Racing
              • 3423
              You didn't miss it mate. It seems I never mentioned it when I finally put it all together.
              It was bought from Himodel many years ago. A dual motor output rock crawler ESC. It has amazingly smooth low speed control. As in, you can count the revs.
              I don't know the brand or the amperage. And I can't find any on the web any more. Sorry. But any 20A ESC will be more than enough.
              Here's a couple of pics if you or anyone else can recognise it. A good view of some of the lead ballast too.
              It would be good to see a few pics of your boat too.
              Cheers.
              Paul.
              • Jesse J
                scale FE enthusiast
                • 7818
                Looks stunning out on the water. I had a thought.. what about a removable sailboat keel with weights? I suspect she leans outward on a turn? Nobody would know and I wouldn’t tell if you did this crazy idea.
                As for esc, there is at least one dual motor, waterproof crawler option out there. Try hobbywing or turnigy. I just set my dad up with one And two 55t crawler motors, and he is super happy with it.
                "Look good doin' it"
                See the fleet
                • 785boats
                  Wet Track Racing
                  • 3423
                  Thanks Jesse.
                  I managed to have another few runs with it yesterday, & the internal weights seem to work pretty well.
                  So, although I've seen it done, an external weighted keel won't be needed.
                  I also reduced the prop from the 30mm to a 26mm prop & that eliminated the torque roll at full speed.
                  Top speed at full throttle is now less, of course, but still slightly above what I would consider a scale 18 knots. The top speed of the original boat.
                  So it all balances out very nicely.
                  I'm kicking myself that I didn't get a fellow club mate to take a video of it. Next time for sure. But a club mate posted these photos on our clubs' facebook site though.
                  I found the ESC. AliExpress still sell them. But man, are they expensive now. Only cost 20 odd bucks a few years ago. I only used it because it was in the spares box.
                  It's actually rated to 75A.
                  I've started building a big cabin cruiser with twin 775 brushed motors in it, so I will use it in that & just get a cheap 20A ESC for this boat.
                  Here's a link with the specs.
                  https://www.aliexpress.com/item/32484596411.html
                  EDIT.
                  Went to a different club this morning & one of the guys was kind enough to take a video of her.
                  The noisy coupler sounds louder than it really is. I'll replace it with a quiet one though.
                  Cheers.
                  Paul.
                  • Jesse J
                    scale FE enthusiast
                    • 7818
                    Beautiful!! Nice job getting video. Now... the perpetual onlooker requests.. rougher water, slo mo and a pesky sub to go get...
                    She rides real nice!
                    See the fleet
                    • 785boats
                      Wet Track Racing
                      • 3423
                      Thanks Jesse.
                      That type of video would be great. I will get some footage in rougher water one day.
                      We do have guys that run submarines in our club. But they are all big. The scale would look weird.
                      We'll see what we can do when things get back into full swing after more of the virus restrictions are lifted.
                      At the moment we are only allowed 10 people at a gathering here, but in a couple of weeks they are talking about changing it to 20 people. So a few more members should start turning up at the club.
                      • JestDanny
                        • Jan 2017
                        • 176
                        Congratulations, winner photo contest RCG. fantastic model
                        PROBOAT BlackJack 24", ShockWave 26"
                        MRP U-31, 3 tunnels VS1, MRP Bud Light, Dumas HS Sprint
                        • 785boats
                          Wet Track Racing
                          • 3423
                          Thanks Danny.
                          It was quite a shock, as there were plenty of other photos that I considered to be better.
                          • 785boats
                            Wet Track Racing
                            • 3423
                            I travelled down to our Logan City model boat club last weekend & one of the guys that posts photos on our facebook site each week caught this boat heeling over beautifully in a turn, in a bit of mild weather.
                            such a nice photo that I had to share it.
                            Here's a link to the facebook page if you want to see some of the other models in action too. It's a great club to be part of.
                            https://www.facebook.com/Logan-City-...=page_internal
                            • sciesielka
                              • Aug 2019
                              • 90
                              Beautiful model! Looks incredible sitting still and even better running!
                              I haven't spent enough time in the scale models portion of the forums, but
                              I should.
                              Seeing your models has inspired me to keep working on my PT boats. I got them running again in 2019 but still need to fix them up. They're both 30+ years old.
                              Keep up the great work and thanks for sharing your incredible modeling skills with all of us!
                              Info and pictures about our Invincible Razor build, Lindberg PT Boats; Racing Runabout; Pro Boat Stealthwake and more! Plus videos of our boats including upgrades, repairs, etc.
                              • 785boats
                                Wet Track Racing
                                • 3423
                                Thanks for the compliment mate.
                                But yes for sure finish refurbishing your PT boats.
                                Start a thread in this section so we can all enjoy your hard work.
                                I love watching people re-work old boats.
