Skippies and Kiwis
  • drwayne
    • 3012
    #3766
    Doc W,
    Found this on Hobby King. It might help those that have issues with Spektrum radios and Turnigy Aquastar/Hifei Swordfish esc's. I have not tested it with mine so I can not comment on the validity of their claim but you can bet your bippy I will soon.
    Calibrating Aquastar 120A and Spektrum DX3S.
    You have to program your TH Subtrim to B100, and Th Punch to 4%. After that, with your TX on and while TH all the way back (TH FULL), power up your ESC. During 4 beeps, release the TH. Your should get your ESC calibrated.
    Hope that helps!
    Subtrim does not affect total Throttle range.
    rev:neutral:fwd
    -100:0:100
    set subtrim to B100 makes
    -200:-100:0
    result neutral to WOT still 100 range
    Hifei want at least 500microsecs for pulsewidth range 0-100% Th, and apparently Spektrum dont quite supply that.
    Increasing endpoint may do the job
    for example only, dont quote the figures.
    Spektrum endpoints std at 0-450us equates 0-90% of esc Th
    set Th fwd to 150%
    -100:0:150
    450usx150% = 675us
    recalibrate. well within the 500us pulsewidth to achieve 0-100%
    Have seen this before, and the mr3000 known for it.
    The mr2000 does not display this issue.
    ps Spektrum are a really good product, dont take this as negative.
    W
    • Xzessperated
      • Apr 2008
      • 3063
      #3767
      Thanks Doc. I think I will change my 3000's to 2000's
      rev:neutral:fwd
      -100:0:100
      -200:-100:0
      set Th fwd to 150%
      -100:0:150
      450usx150% = 675us
      W
      • Xzessperated
        • Apr 2008
        • 3063
        #3768
        I took my favorite rigger to the lake yesterday and came home with a big smile on my face. For an oval boat it sure has some speed. 128 kph = 79.53 mph and the best part is that I can do ovals on my small lake.
        • Flying Scotsman
          Fast Electric Adict!
          • Jun 2007
          • 5195
          #3769
          That is impressive Paddy....was the lake like glass?
          Douggie
          • Xzessperated
            • Apr 2008
            • 3063
            #3770
            Douggie
            Douggie,
            It was like glass until the first circuit was completed. It likes the disturbed water or even a small chop. It would make a good race boat. I am not sure if Jeff Luca (previous owner) raced it in the USA or not. Mine is not a race setup as I run it a little on the hot side with 5s and one of Andys props but it is capable of 3 laps without a rest to cool it off.
            PS 6s to come and should be in the high 80's but SAW runs is all I will try on that battery
            • RandyatBBY
              • 3944
              #3771
              Just thought I would stop in a see what you guys were up to and low and behold look what I see, one of my Baby's. Glad you like it! Jeff did race it and loved it. I never heard much though.
              Randy
              BBY Racing
              • drwayne
                • 3012
                #3772
                Sprint Cat 40 update
                I was contacted by Remy@aeromarine who offered to replace the flucked gel cowl from the sc40.
                Great service @Aeromarine .
                Offered me an option of turbine or 7-11 type.
                Took the 7-11... no need to seal the turbine .
                14 days, voila, arrived in 100% perfect condition.
                What the ?....it doesnt fit the sc40. !
                Apparently Aeromarine use sc40 to identify the shadow sports hydro 40...go figure.
                chuckle.. asked what abbreviation for the sprintcat40 .. ????????????????
                So here I am, still with flucked gel cowl, and Ive a ShadowSportsHydro 40 cowl with no hull.!
                Remy then offered to send out the sprintcat40 classic cowl.. to whit I offered to buy the sportshydro40 hull, and he ships the sprint cowl with hull.. hull+freight at my cost.
                waiting on a reply !
                W
                • Xzessperated
                  • Apr 2008
                  • 3063
                  #3773
                  W
                  [ATTACH=CONFIG]63692[/ATTACH]
                  Not going to get you to put a bet on a horse for me this month with the luck you are having Doc. I hope the problem gets sorted.
                  • Xzessperated
                    • Apr 2008
                    • 3063
                    #3774
                    This arrived via courier yesterday...
                    • drwayne
                      • 3012
                      #3775
                      Yup.
                      During this latest lifetime Id make a good poster boy for 'shh, it happens' ...........
                      • Xzessperated
                        • Apr 2008
                        • 3063
                        #3776
                        Not sure what paint job it will get but those colors have me thinking a Packers theme.
                        • Xzessperated
                          • Apr 2008
                          • 3063
                          #3777
                          I cant get over the size of these capacitors...
                          • egneg
                            • 4759
                            #3778
                            You have my vote, 8 wins/0 losses. Best team in the USofA!
                            IMPBA 20481S D-12
                            • drwayne
                              • 3012
                              #3779
                              I cannot get over the size of the hull .. it's a whopper !!
                              That esc is almost 6" wide.. and it doesnt even touch the engine rails !!
                              • Xzessperated
                                • Apr 2008
                                • 3063
                                #3780
                                The Packerization of the boat begins...
