119 kph or 73.94 mph on 3s lipo
Well guys I took my little modified Xzess 2 rigger to the lake this morning and was I in for a surprise. First let me tell you that the last time I took it to the lake it found the only hard object (a 3 foot square of concrete) on the entire northern bank and severely damaged one sponson (the one with the Packers girl with the counter rotating Andym's). The main hull had some damage too. It has been repaired but I have not even sanded the epoxy back yet. The main reason to take it to the lake was to see if it had any leaks
The first run was a little off course so I never hit full throttle but it came back with the GPS showing 113 kph and I knew I had struck gold. Next run was straight down the line that leads between the island and the northern bank. I squeezed that trigger all the way and that little sucker was flying. There was no sign of it lifting the nose. I turned it around slowly (no turn fin) and lined her up for the run back to me. Man that little bugger looks good coming at ya. I looked down and could not believe the 119 kph that I was looking at on the GPS. I reset the GPS just to make sure it was correct and next run it showed 119 kph again.
Setup was...
Xzess 2 modded, Neu 1515 0.5Y, 3s Turnigy nano-tech 5000mAh, Andym Very Special X642, Hydra 240 lv and a Tasmanian that is all bloody smiles at the moment. Andy what can I say except thanks again for your brilliance with props and your friendship.
BTW there were no leaks
For some reason this was not a good picture but I added it anyway.
