Skippies and Kiwis
  • Xzessperated
    • Apr 2008
    • 3063
    #3886
    I thought it was about time I gave some of my other boats a run.
    First cab off the rank was my BBY oval rigger. This has to be my best all round boat. It is fast in a straight line and the corners. As you can see it was very close to 70 mph and that was on an old slightly puffed lipo. It has hit 78 mph on a good battery.
    Next contender to enter the ring was the ex Doc W Maritimo. I love the sound of the screaming twins and the way this boat sits on the water at speed. This was it's first trip to the lake after water claimed one of the Swordfish esc's. It was down on its usual speed but once again I was using a battery that needs tossing.
    • RandyatBBY
      • 3943
      #3887
      Did you get any Video? I had forgotten what that boat looked like thanks. I need to put together my twin HPR 44 inch cat. it should hit some high speeds on 4S2P 5000mAh, CC 240LV Hydra and Neu 1527 .5Y. with counter rotating 447 props. It needs Paint first.
      Randy
      BBY Racing
      • RandyatBBY
        • 3943
        #3888
        Originally posted by Boaterguy View Post
        yesterday it hit -25C here in hockey/ beaver country
        That is pretty comfortable, it is 62F degrees hear at 2:30PM
        Randy
        BBY Racing
        • Boaterguy
          • 1779
          #3889
          comfortable? 62F is above 0F, how is that comfortable?
          • Xzessperated
            • Apr 2008
            • 3063
            #3890
            I have some old videos of both boats Randy. I will be getting more of both boats soon and will post them.
            2 to go on with until I post new ones...
            BBY Circuit Rigger
            Maritimo Twin
            • RandyatBBY
              • 3943
              #3891
              comfortable? 62F is above 0F , how is that comfortable?
              well translating Farenheit to Celsius will help you. but if that does not help the note below may help.
              I was in long pants, tee shirt, no wind, in the sun and sweating.
              Randy
              BBY Racing
              • Flying Scotsman
                Fast Electric Adict!
                • 5195
                #3892
                Damn it Paddy you have to learn to take a corner as I have said before.....sounds great though on the twin....now I want to see you manage a circuit at full speed.
                Douggie
                • egneg
                  • 4759
                  #3893
                  I now have a way to deal with boats that are faster than mine ...
                  IMPBA 20481S D-12
                  • Boaterguy
                    • 1779
                    #3894
                    I meant 0C lol
                    are you saying I should be comfortable in -25C?
                    • RandyatBBY
                      • 3943
                      #3895
                      I meant 0C lol
                      No I like much cooler temperature than most people (64 to 71 degrees Fahrenheit) . But I relate to Fahrenheit temps because I have used them all my life. I get mixed up a little seeing Celsius and need to convert to understand. mostly my problem.
                      Randy
                      BBY Racing
                      • Boaterguy
                        • 1779
                        #3896
                        i agree about the cooler temperatures but -25 is too cold.
                        take it this way - 0C is 32F, and they meet at -40.
                        • Xzessperated
                          • Apr 2008
                          • 3063
                          #3897
                          The Drambuie On Rice was tested again this morning on 9s. I adjusted the strut a little to keep the nose down to prevent blow-overs. That worked remarkably well. Speed went down from 108 kph on 9s to 99.4 kph and there maybe room for some fine tuning to gain back a little of the speed but I would rather a boat that stayed on the water so for the moment it will stay as it is. I have to test it on 10s, 11s and 12s yet so a lot more speed to come from batteries if it stays on the water.
                          At Chucks request I have uploaded 3 more videos for his viewing pleasure
                          Here ya go Chuck
                          • Flying Scotsman
                            • 5195
                            #3898
                            Paddy, you are learning laddie....keep the bitch on the water and not upside down. Also speed is not always the answer, I suggest you ask June about your 60 second sexual encounters?
                            Douggie
                            • RandyatBBY
                              • 3943
                              #3899
                              One thing to watch wetting down the hull is temps. A more freer run will be cooler, when you run wetter the temps will go up. More to balance in to the equation.
                              Randy
                              BBY Racing
                              • Xzessperated
                                • Apr 2008
                                • 3063
                                #3900
                                As you said Randy things are are starting to warm up a little now that the hull is running a little wetter. Last night I got to it and ran water cooling to the esc. Worked a treat.
                                This morning the boat was tested on 10s and speed was 110 kph or 68.35 mph and still a little wet, but as I have 11s and 12s lipos to come I am not changing anything yet. The boat gives me confidence that it can go a lot faster now without a blow-over.
                                I finally filled that hole in for you Doc
