Pro Boat UL-19 prop ?
  • hydromark55@att.net
    • Apr 2021
    • 1
    I'm looking for a better performance prop for the Pro Boat UL 19. Ideas? Results? Thanks
  • Doug Smock
    • 5359
    Hey Mark,
    You may find some help here.
    https://forums.offshoreelectrics.com...oplane-Q-amp-A
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • melissacisneros
      • May 2023
      • 1
      I was looking for one too but it seems to have sold out. Replacement vertical fins for UL-19 30-inch Hydroplane ; Stock UL-19, Veles 29, & Miss Geico Zelos Propeller 1.7. elastic man
      • Bande1
        • Mar 2023
        • 678
        42mm 1.6 pitch seems to be popular. so much so that literally no one has one from any brand in stock.
        • lindsaycota
          • Jul 2023
          • 1
          I think they're all out of it now.
          • Xrayted
            • Jan 2023
            • 273
            Yes I have that same OSE prop. It is a 1.65 (42mm) diameter with a 1.4 pitch. Same total pitch as an Octura X442 if you can find one of those as well. Its a very commonly suggested prop for the UL-19 to keep the current draw and temps down, although I dont have that specific model myself.
            I run mine in my 36" mono on 6S if I want to run continuous heat racing laps. I use a 1716 which is the standard prop setup on the Pro Boat Miss Geico twin for SAW like fast laps on the same 36" mono. It will run 80mph on the 1716 prop, but you have to be careful with the temps on 6S and let it rest between runs a bit
