machining help needed
  • JimClark
    • 5913
    I have a broken part on my tablesaw fence that is not available. Could anyone with a lathe make me a couple of them out of PTFE? They measure 15/16 diameter are 7/17 wide and the hole in the center is .265.
    Billy Graham
  • longballlumber
    • 3417
    Jim are you talking about the roller white roller?
    does it take any stress/load?
    I might be able to get you something off of my 3D printer. Can we improve by adding bearings?
    Either way I need OD, ID, and Width
    • JimClark
      • 5913
      Yes the white bearing. It just holds the back end of the saw fence up and rolls on a piece of Angle iron. The diameter is 15/16 th's width is 7/16th's and the hole is .625
      Sent from my Moto G (4) using Tapatalk
      Billy Graham
      • Mike W
        • May 2018
        • 348
        It may have worn/shrunk over the years from an original size of 1" x 1/2". If so one of these should work:
        Otto RC Marine
        • JimClark
          • 5913
          Thanks Mike but I dont see anything there that I could drill out the hole to 17/64 without messing up an expensive roller.
          Billy Graham
          • trigger
            • Sep 2013
            • 853
            I hope these get you going......
            • JimClark
              • 5913
              Looks great thank you very much. PayPal coming your way
              Billy Graham
