I'm just looking for some pointers and where I can get some bright green dye. I have some of the equipment already and I'm wanting to get started.
Anyone know how to anodize?
i have half a bottle of bright green dye from a guitar i did. you can have it. want me to try it on a piece of aluminum?There's a hole at the center of earth where the rest of the world sinks but i stand still...
That would be awesome!Originally posted by Luck as a Constant View Posti have half a bottle of bright green dye from a guitar i did. you can have it. want me to try it on a piece of aluminum?32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
its probably close to that. ill see what it looks like on aluminum and send a picThere's a hole at the center of earth where the rest of the world sinks but i stand still...
Negative.
The dye wipes rite off.
I let it sit,,, no different.
I tried heat, which did help, but water washed it rite off.
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...
Hell no.
Watching YouTube vids it looks like a pita.
The home powder coating kits look cool tho.
The dye is darker than you need anyways btw
I have some black fiebings leather dye I can try if you want. At least youde know if it is any better....
I wanted to actually anodize it. Yes it's a process. You can use rit dye but I haven't seen a green like I want. I have a full powder coat out fit with two guns and a harbor freight 18"x18" powder coat oven. Doing screws and small stuff like I want is a pita. I have that green in a powder but it's a two stage. You lay the base green. Bake. Then lay a clear. Bake. Way too much crap. Here's the color on one of my sand drag 4 wheelers a arms...
Well can you mix colors to get the desired effect?
Rit dye is so cheap. Just experiment.
Mix yellow with a drop of blue.
Try lightening the rit green with yellow.
One has to work
To me, the color looks more on the yellow side of green.
I would start with yellow and add blue until it looks rite.
You even have Green scissors... haha
Is that an older picture? I see a Camaro....Why are you bothering me? I want to see your boat!
