Top Fuel Dragster Facts
  • RandyatBBY
    • 3915
    Stolen from Ranchero Richard on Ranchero USA.
    Ever wonder why a Top Fuel dragster gets a rebuilt engine after each run?
    Stay with this — even if you aren't a 'car nut', this is stunning.
    * One Top Fuel dragster outfitted with a 500 cubic-inch replica Dodge (actually Keith Black, etc) Hemi engine makes more horsepower (8,000 HP) than the first 4 rows of cars at NASCAR's Daytona 500.
    * Under full throttle, a dragster engine will consume 11.2 gallons of nitro methane per second; a fully loaded Boeing 747 consumes jet fuel at the same rate but with 25% less energy being produced.
    * A stock Dodge Hemi V8 engine cannot produce enough power to merely drive the dragster's supercharger.
    * With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lockup at full throttle.
    * At the stoichio metric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F.
    * Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
    * Dual magnetos supply 44 amps to each spark plug. Which is typically the output of an electric arc welder in each cylinder.
    * Spark plug electrodes are totally consumed during a pass. After 1/2 way thru the run, the engine is 'dieseling' from compression and the glow of the exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
    * If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with enough sufficient force to blow the cylinder heads off the block in pieces or split the block in half !!
    * Dragsters reach over 300 MPH +... before you have completed reading this sentence.
    * In order to exceed 300 MPH in 4.5 seconds, a dragster must accelerate an average of over 4 G's. In order to reach 200 MPH well before reaching half-track, at launch the acceleration approaches 8 G's.
    * Top Fuel engines turn approximately 540 revolutions from light to light!
    * Including the burnout, the engine must only survive 900 revolutions under load.
    * The redline is actually quite high at 9500 RPM.
    * THE BOTTOM LINE: Assuming all the equipment is paid for, the pit crew is working for free,
    & NOTHING BLOWS UP, each run will cost an estimated $1,000 per second.
    0 to 100 MPH in 0.8 seconds (the first 60 feet of t he run)
    0 to 200 MPH in 2.2 seconds (the first 350 feet of the run)
    6 g-forces at the starting line (nothing accelerates faster on land)
    6 negative g-forces upon deployment of twin 'chutes at 300 MPH
    An NHRA Top Fuel Dragster accelerates quicker than any other land vehicle on earth . .. quicker than a jet fighter plane . . . quicker than the space shuttle....or snapping your fingers !!
    The current Top Fuel dragster elapsed time record is 4.420 seconds for the quarter-mile (2004, Doug Kalitta).
    The top speed record is 337.58 MPH as measured over the last 66' of the run (2005, Tony Schumacher).
    Let's now put this all into perspective:
    Imagine this......…..
    You are driving a new $140,000 Lingenfelter twin-turbo powered Corvette Z-06. Over a mile up the road, a Top Fuel dragster is staged & ready to 'launch' down a quarter-mile s trip as you pass. You have the advantage of a flying start. You run the 'Vette hard, on up through the gears and blast across the starting line & pass the dragster at an honest 200 MPH….
    The 'tree' goes green for both of you at that exact moment. The dragster departs & starts after you. You keep your foot buried hard to the floor, and suddenly you hear an incredibly brutally screaming whine that seares and pummels your eardrums & within a mere 3 seconds the dragster effortlessly catches & passes you. He beats you to the finish line, a quarter-mile away from where you just passed him. Think about it – from a standing start, the dragster had spotted you 200 MPH.....and it not only caught, but nearly blasted you off the planet when he passed you within a mere 1320 foot long race !!!!
    That, my friends.....is acceleration.
    Randy
    BBY Racing
  • keithbradley
    • 3663
    Cool stuff Randy. The second one (11.2 gallons per second) is a misprint though. Perhaps you meant to type 1.2gallons?
    www.keithbradleyboats.com
    • RandyatBBY
      • 3915
      I just coped and paste. 261 MPH in 3 to all most 4sec, 8000 HP 11.2 GAL THREW AN SUPERCHARGER in to a Keith Black hemi sounds right to me, but heck my mind is seldom home. Have you ever seen a TF dragster hemi it is a little over 3 ft wide.
      Randy
      BBY Racing
      • keithbradley
        • 3663
        Yes, I built (and raced) drag cars before I entered the world of RC. That's actually how I got started in fast radio controlled cars and boats. After getting married and having kids, I agreed to stay out of race cars, but quickly learned that I needed to find another way to satisfy my desire to create and run fast machines. RC became my way to go fast, but stay safe. I imagine there are a few guys here with similar stories.
        Top fuel engines aren't all that large (compared to some of the other engines used in drag racing. Supercharged Pro Mod for example is 526 C.I., and some N/A and nitrous motors are over 800 C.I.). They are limited to 2 valve, 500 cubic inch engines. They are also limited in many other ways, like having to use superchargers that are of an inferior design compared to what can be used in T/A and Pro Mod.
        I think the T/F fuel system is still capable of around 75-80 gallons per minute, which is an incredible amount, but still only a little over a gallon a second. 11.2gal/sec would be nearly 700gal.min.
        • TristanJones
          • Oct 2012
          • 266
          I'm from a similar background to Keith by the sounds of it, been around and involved in drags since about 6yrs old LOL. Still active in both full scale and Rc drags.
          Times this by 8..... its a lot of juice!!
          • TristanJones
            • Oct 2012
            • 266
            While we are talking fast and straight line...
            worlds fastest RC drag car, was run just over a week ago here in australia.
            • RandyatBBY
              • 3915
              Well it is Monday and I am visualizing the orifice to release 11.2 gal a second like the size of a 5 Gal bucket!
              Cool run on the RC Drag car.
              Randy
              BBY Racing
              • don ferrette
                • 1093
                Guys, those "top fuel facts" have been around the cyberspace route before, the 11.2 gallons is a typo, it should have read 1.2 gallons a second. Think about it for a second, when was the last time you saw a top fuel dragster stage at the lights with a 50 gallon fuel cell? And that's just what it would take to get down the track in a little over 4 seconds without pulling up to the staging area running, the burnout to heat the slicks up,etc. if it was 11.2 gallons a second.
                - IMPBA Hall of Fame -
                - IMPBA Hydro Technical Director -
                • TristanJones
                  • Oct 2012
                  • 266
                  big block nitro motors have about 6 or 8 fuel nozzles per cylinder (there is even some in the head behind the valves LOL) . 11.2 gal per run is accurate, and scary.
                  Yeah, thanks, Brendans Rc Drag rail is crazy!
                  • RandyatBBY
                    • 3915
                    Thanks guys for the info back, I have been to a lot of drags Fontana, Riverside, Fremont, Pomona and many more in the 60ties, I never finished building one when I was young I would get about $5000 in to old junkers and needed to pay rent and had to stop. I swore off them for about 10 or 12 years then after my son was born in 1982 I got back in to it and have been building street rods every since. When I found RC Racing in 1989 I knew I could afford it.
                    Randy
                    BBY Racing
                    • TristanJones
                      • Oct 2012
                      • 266
                      I have a bit to do with a few street rods and drag machines mostly small capacity engines with LARGE turbochargers here in Aus.
                      On a side note, I have one of your BBY saw riggers here. :) Cant wait to power it right up and see what it can do :)
                      • RandyatBBY
                        • 3915
                        I always wanted to see a Honda Vtec in a 29 roadster or FG bucket tee.
                        I just pulled the last mold for the twin Lift Master Rigger.
                        Randy
                        BBY Racing
