who is good at math
  • gultch
    • Jan 2011
    • 66
    who is good at math
    hi all
    can someone pls verify my math on an equation
    the scenario is i need to work out the metric tonne pressure from a pounds per square inch reading on a vertical hydraulic test rig here goes
    hydraulic ram diameter is 1.5 inches the psi is 4000
    first area of cylinder 3.14xdxd divided by 4 =1.767
    multiply psi x area 4000x1.767=7068
    to convert to metric tonnes divide by 2.205 7068divided by 2.205=3.205 tonnes
    any one see a problem with this thanks in advance for your time
    gultch
    genesis leopard 4074 2000kv t180/ hk vanquish cc1717 hydra 240/ fibreglass carbon hydro 38" build in progress
  • siberianhusky
    • Dec 2009
    • 2206
    PSI x .07 = kg/cm
    7068 x .07 = 494.76 kg/cm2
    This what you were after?
    • gultch
      • Jan 2011
      • 66
      not quite i just need a learned person to verify my math as stated thanks for posting though
