Proboat Veles 29 Green blinking/beeping light
  • idoccurt67
    • Jun 2020
    • 4
    Hello all. I have a new Veles 29 proboat. It ran fine last time I took it out, but after i recharged batteries, when i turn esc on the green light just blinks and beeps every few seconds without any power. Im thinking it could be a battery issue. Any help would be great as i am new to this. Thanks
  • eehess81
    • Jun 2021
    • 158
    Do you have rudder control? Check esc connection to receiver make sure it's plugged in all the way. May need to recalibrate esc. Turn on transmitter and hold full throttle. Plug in battery and turn on esc. If the esc beeps release throttle. May need to then do full reverse, not sure on esc calibration for that boat. Check the manual.
      • 4338
      I agree with all of eehess81's suggested steps. Also check your throttle trim is still set at zero on the transmitter and that the throttle channel was reversed if the transmitter has a switch for that.
      • eehess81
        • Jun 2021
        • 158
        It's usually not a battery issue if there is no damage to battery.
        • eehess81
          • Jun 2021
          • 158
          I also agree with fweasel on the throttle trim ��
          • crowwell
            • Jul 2022
            • 1
            The included transmitter and receiver are bound at the factory. If you need to rebind, follow the instructions below. 1. Ensure the transmitter and vehicle are both powered OFF. 2. Install the bind plug in the BIND/battery port of the receiver. 3. Power ON the vehicle. The receiver LED will blink. 4. Stand approximately 8–12 feet (2.4–3.7m) from the vehicle. With the steering wheel and throttle trigger in the failsafe positions (neutral), press and hold the bind button and power ON the transmitter. The transmitter’s green LED will blink after 3 seconds, indicating it is in bind mode. 5. Release the bind button when the green LED flashes. Continue holding failsafe positions until the binding process is complete. 6. The receiver LED will glow solid when the transmitter and receiver are bound. 7. Power OFF the vehicle, then the transmitter. I had a similar problem when I switched to smart strip lights.
