I have in my collection of 1:1 outboards something called an Electric Oar. It is just what it says it is, an oar with an electric motor mounted on it, connected to a long shaft with a propeller on the other end. These aren't mine, but you get the idea.
Electric Oar - An Outboard of a Different Sort
Tags: None
The one in my collection is a home-brew version of the Grimes pictures above, nicely done, with some modest simplifications (no gang switch, just a single knife throw), and a car starter motor for power.
Anyway, I decided to make a scale-ish model of an Electric Oar. Not necessarily an exact copy, but close enough. I started, where else, with the oar... Laminated several pieces of mahogany plank, rough shaped, then some time sanding and shaping to achieve the look of a St. Lawrence Rowing Skiff oar.
For the drivetrain, I am using a simple Mabuchi RE-260 can motor, hooked to a piece of coat hanger wire for a driveshaft via some tubing. The propeller for the moment is just a plastic prop off a toy my step son broke many years back.
Taking shape...
One coat of sealer on the oar, and some brackets made of brass shim stock to support the motor and shaft. Also picked up some 0-80 brass machine screws to tie it together...
Thanks! I actually have a 1922 version of those called a Caille Liberty, gas powered, single cylinder. I think they call that style a mud motor these days. The swamp folk down on the bayous run them.
Not really planning on powering anything with it. May toss it on a Fleet-Line toy boat I've got just for grins, but otherwise, it'll likely end up as not much more than a dust catcher / conversation piece. Might make a stand with a built-in battery pack and a push button so I can just spin it up when I feel the urge.
