XBE long chassis
  • twissted
    • 896
    XBE long chassis
    something that is still being worked on now and again.
  • Wetter
    • Aug 2013
    • 241
    you still crack me up!
    dude i still have to invent a lock for your box.
    that's almost indestructible
    • twissted
      • 896
      Some light reading...
      • twissted
        • 896
        VIDEO:
        This is another one of a kind build that I did. And yes, it's 2 fast 4 U!!!
        • Wetter
          • Aug 2013
          • 241
          i tried to watch but somethn' taint workn' on the you tube, my computer genius son is going to have to reinstall some type of new script, it comes and goes, damn i miss windows 95
          • twissted
            • 896
            I'm up grading the shocks at the moment. Spendy little buggers! Losi Team shocks.
            I have the rings from FID Racing on the way. The rebuild kit I ordered was short some seals and they are on the way as well. should be done this week.
            • twissted
              • 896
              I have Ultra Rings for Baja 5B / 5T and Losi 5ive-T by Hostile Racing Products that are green to match the springs on the way as well.
              • twissted
                • 896
                Here is what will be my X-Mas pressent. they should hold all the power that will be put to the ground. Made by 7075rc.
                At 105.00 apiece there not cheep, but breaking parts isn't cheep or fun.
                • Oexak
                  • Nov 2013
                  • 10
                  That baby is going to run wild once its ready.
                  cleaning robot
                  • twissted
                    • 896
                    added the adjustment ring and the bead locks.
                    • twissted
                      • 896
                      This is a stretched XB-E that is currently getting new diff housings in front and rear they and the wheel hubs are made by 7075rc. 24mm hex adapters are Ramtech and the motor is the beast 524 2Y 910 kv motor with 200 amp esc that has caps added running on 8s Nano-tech 65-130c 5000 lipos. carbon fiber body is vac bagged with impact resin making it 18 time stronger than the losi body. And is lighter to boot!
                      • twissted
                        • 896
                        I'm still waiting on bearings that was missing with the order, for the wheel hubs and carriers.
                        • twissted
                          • 896
                          Maiden run with camera on board!!
                          I changed the front springs to the Losi 5 blue (have them on back already) and loosened the motor pinion gear so it not noisy any longer.
