HVAC Home thermosat Q, need help please
    Hello all yee HVAC guru's! I know there are a couple or at least one skulking about in here.
    I have this thermostat in my apartment. It controls my own independent HVAC unit that is electric forced air plus an A/C for summer.
    I would like to know about the center dial and how to set it so the temp keeps more stable on cold days.
    It has some wording on it but, it doesn't seem like any cycle changes when I swing that little metal dial to whatever place.
    It is very old and if I wanted to replace it how would I know which wire goes where on the new one (assuming it will be different??)
    I know the basics, as the mercury switch falls to the right the heater turns off as it goes the other direction it triggers (closes cct) and heat turns on.
    On damp days like today it seems like I cannot get warm no matter what, well unless I crank the hell out of the heat.
    Since the thermal coil is so old and caked with Nicotine and tar from previous tenant, could it be out of calibration causing improper temp reading? I dunno, it drives me nuts. I'm either too cold or too hot...
    Maybe it's Manopause?? LOL...
    Any help is greatly appreciated!!
    Chillin'
    oops pics
      I took a good look at it and full CCW it has shorter cycles and CW it is longer. I also grabbed the casing and twisted it on the wall CCW about 1/16" and it of course now turns on.
      Just lloking for some techno info on this thing so I know what to do or NOT to do.
      • silver
        • 84
        this is a very old one but there are still working well in the field i see sometimes thouse things no the airco units form Lennox where i work for.
        this is a kwik thermostat that has a function fan auto means on/off depending of the temperature and Fan on than it goes all the time.
        there is also a contact between cool and heat.
        the temperature is mesured by the metal spiraal that moves the kwik contact(bulp).
        very simple, i don't wave draings from this thing but its nit that difficult tu figger it out
        good luck
          Thank you. I'll keep playing with it.
          I took off the outer Thermometer because it may have been touching the mercury switch stopping it from moving properly. We'll see how it goes.
          I set it to the shortest setting.
          • HydroMike
            • Oct 2011
            • 338
            That's out of date if u go to Lowes they have new t-stats what u are looking for is just a normal heat-a/c t-stat. The wire colors should be red (24),white (heat relay),yellow (a/c contacts),green (fan relay), and sometimes blue for common wire these are the basic. Just keep track of the wires the u take off and what they go to. And before starting turn power off
              There should a main kill switch on the wall or on the heater,
              And that will turn turn off the 24v transformer for the thermostat control wires.
                Thank you very, very much. I will think twice about it. There is possibly one personal friend that might be able to come over and help too.
                Power off, that's a nice reminder because those wires are so tiny. Green definitely fan relay because the last repair guys left that wire unhooked and I was wondering why I couldn't get the fan on by itself for so long.
                  Yes, but I would most likely need to take the front cover off and thats maybe too deep of a hole to dig... We will see. I will most likely wait until it's nice and warm before I do any changes.
                  What is nice is that I get so much advice so fast because it is an electric based forum, at the touch of a keyboard... Bada bing!
                  Thanks Steve for a great forum and thanks for all and any advice guys!
                  • Doug Smock
                    • 5359
                    Ray,
                    Make sure that the thermostat is level.
                    The "center dial" is the heat anticipator. The correct way to set it involves checking the load on the white wire and setting it accordingly.
                    This will give you a good understanding.
                    Or you can just play with it until your warm and fuzzy.
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • HydroMike
                      • Oct 2011
                      • 338
                      I don't think that will imply for his electric heat that's more for gas or oil
                      Originally posted by Doug Smock View Post
                      Ray,
                        That was a cool video! Thanks Doug.
                        Yes it is electric but, the concept is the same I believe. With my heater the element and fan would come on at the same time, I think... Now I need to borrow a clamp meter. I could do it with shunt but, haven't done that since High school.
                        Now I get it... Oh the anticipation... to be warm & fuzzy
                          Gotcha, will do that too. Need to borrow that too.
                          I'm late to dinner... ttyl...
                          Ray,
                          • Doug Smock
                            • 5359
                            I should just delete your post cause you're WRONG. LOL
                            Gas heat the gas valve is the load. In his electric unit he has either a contactor, sequencer, or a series of either (depending on the KW) that is the load wired in series with the heat anticipator.
                            If you don't believe that Ray cut that little silver wire and go get your quilt. LOL
                            Here is an example of a sequencer. (probably what you have)
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                            • Doug Smock
                              • 5359
                              The drawing at the top of page 4 shows you how the heat anticipator is wired in series with the control load.
                              MODEL BOAT RACER
                              IMPBA President
                              IMPBA 19887L CD
                              NAMBA 1169
