Thanks bro, it's actually ebony fretboard. Should sound killer. I process the crap outta it anyways ,so the pickup will determine the sound more so. Thinking emg 81 18v or Gus g Seymour's.
Custom Guitar Build
thanks bro. the nitrocellulose is put on 2-3 coats per day, 1-2 hours apart. the nice thing about nitro is you dont need to sand between coats or even after the next day, just spray. after i get all my coats on, i will sand it level, and apply a final coat thinned about 50/50 then wait about two weeks to sand with 1000 and 1500 grit paper, let that sit for couple of days, then buff to a nice high gloss shine.Originally posted by tlandauer View PostEvery step looks fab!
I am enjoying and learning something meaningful here, thanks for this thread!
What is the interval you need for the nitrocellulose to cure?
Thanks!
Sorry Dana, I really don't mean to spoil this wonderful thread but I am just too curious: What do you use to thin it? Also when you mentioned "spray", you mean that you are using a professional sprayer, right? They don't come in a can. lol... You see, I wanted to know what I canuse to safely remove rosin and gunk on my cello's varnish, they used to sell xylene ( Goof Off), but that stuff is banned and the current product smells like pure acetone to me now. ( acetone is a no-no, in this case) I can't use alcohol, it will take away the varnish. Wonder Turpentine is good?
I apologize for drifting off topic once more!Too many boats, not enough time...
Oh dude you aren't spoiling it man. Yes I use hvlp gun and thin with lacquer thinner of course. Yes you can get nitro in a can, but I don't need to luckily. Spraycan paint is thinned so much to make it spray able, it becomes very costly to get the same film build.
The first thing you should use is water. Most of your dirt is from your hands, and what are humans mainly consisted of? Water. Use water to clean water. Also naphtha is a great cleaner or even lighter fluid. Test spot first tho
Thanks Man! yeah, water is good, but i will def look into naphtha tho.Originally posted by dana View PostOh dude you aren't spoiling it man. Yes I use hvlp gun and thin with lacquer thinner of course. Yes you can get nitro in a can, but I don't need to luckily. Spraycan paint is thinned so much to make it spray able, it becomes very costly to get the same film build.
The first thing you should use is water. Most of your dirt is from your hands, and what are humans mainly consisted of? Water. Use water to clean water. Also naphtha is a great cleaner or even lighter fluid. Test spot first thoToo many boats, not enough time...
Looks sweet! Was just at The Guitar Boutique drooling over Dusenburgs. Ordered up a 3 position switch for a my Strat, back to '63 spec, don't like the phased position sounds and they don't suit what I play anyway.
I'll ask my bass player what he uses to clean the rosin off, not sure he does more than wipe it with a micro fiber cloth.
If it's a real varnish you don't want to use turpentine or anything like that, it will dissolve a real non urethane varnish. I have a 110+ year old mandolin I just put the top back on, no idea what I can use to touch up that finish.
Gotta love a real thin nitro finish, especially after 30 or 40 years of use.
Do you use a sanding sealer or just shoot a coat of thinned nitro to seal the grain?
Also was looking at the specs on some new TV Jones pickups, going in a hot rod rockabilly tele style thing. Going to be a real frankentele, left handed post CBS maple neck, gold Bigsby and tune o matic bridge with a pair or TV Jones Filter Trons. Going to have to route the top to lower the bridge and tremolo.
Thinking chambered mahogany body (already have 2 blanks) with a maple top. Black stain on the top.
Probably use a 3 position gibson style switch and a standard volume/tone setup with a treble bleed on the volume. No pick guard, all access through the back, gold pickup bezels of course.
Picked up enough padouk a while back to make half a dozen fingerboards, be great for a bass not so sure about a guitar. Also scored some mahogany neck blanks thick enough to do a mortise and tenon joint.
I need to take some pictures some time, I never do, not even of my boats! Just not much of a picture guy.If my boats upside down then who owns the one I thought I was driving the last two laps?
Here it is with lacquer done. Now just needs to be sanded and buffed. Almost there
