10w ebay LEDs, questions on power
  • Effie Gubitosi
    • 1
    I know that led light bulbs a constant current source
    the specs on the LEDs I purchased are 9 to 11 volts and 1A or 1000ma
    I purchased 4 of them as well as 4 1000ma constant current drivers for them
    connecting the 4 with the equipment I have is a no brainer
    what Im wondering now is for my future build
    the Flexible LED Strip Lights are going to be used for a DIY aquarium light
    the aquarium currently has fish only and no plants but the second project will be a 55 gallon tank with plants and fish
    my plan for that tank will be 10 cool white 10w leds and 10 blue 10w leds
    I would rather power them all off of 1 power supply
    from what Ive read if I wire the led strip up in series I would need about a 90 volt DC power supply that supplies 1A for each set of 10 LEDs
    I would need a constant current DC-DC regulator (unless I can find a sufficiently powerful constant current power supply)
    I thought about wiring them in parallel but if I had a single LED fry on me the rest would wind up with way too much current and fry as well
    can someone confirm for me if Ive done the math correctly and if I am right in my assumptions?
  • drwayne
    • 3012
    wire them in parallel.
    Fixed voltage power source ( switchmode ) is ideal
    The current provided will follow the load requirements.,
    90V Dc is a lethal voltage.
    Bugger the fishies.. if those leads shorted it would turn you toasty.
    DocW
