Turnigy/Seaking/hobbywing programming card faceplates
  • JPriami
    N4FOX
    • 1711
    I had these then lost them and recently found them again. So since they were hard to find I wanted to post them for anyone else needing them.
    If you have a programming card made by these and need the faceplate here is an image of them.
    Car esc
    Boat esc
  • mappo
    • Feb 2010
    • 496
    Car esc
    Boat esc
    I need this for posterity.
    Do you know what the biggest problem with the world is?
    That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
    • dano1
      • Dec 2010
      • 439
      has anyone had trouble with this card going bad after a first program, seems mine did? cant get it to work on neither one of my esc's, programmed a 180 amp seaking and tried on my turnigy thats a marine esc....nothing .........so i ordered another one, any ideas or am i doing something wrong....i plugged it in correct, battery side to postive and neg....and esc to other port...no responce?
      • dana
        • Mar 2010
        • 3660
        ive heard the program card works with seaking but not the turnigy's so well. not sure tho
        • JPriami
          N4FOX
          • 1711
          I had a similar problem. Found that I wasn't leaving it plugged in long enough. Waited about 5-10sec then it came on
          • JPriami
            N4FOX
            • 1711
            My hobbywing card works with my t-180
            • dana
              • Mar 2010
              • 3660
              like i said, ive only "heard" this. mine works with my seaking just fine. i cant speak for the t180
              • JPriami
                N4FOX
                • 1711
                Knowing is half the battle. Go Joe. Lol.
                Now we both know :)
                • Diesel6401
                  Memento Vivere
                  • 4391
                  T-180 is a Seaking. Cards work on both just fine. I use the same card for the Turnigy Marine series esc's & seakings (IT MUST SAY TURNIGY MARINE), just because it's a boat esc doesn't make it a marine esc (hopefully that makes sense).
                  http://www.hobbyking.com/hobbyking/s...idProduct=8937 same as http://www.offshoreelectrics.com/pro...er-seaking-180
                  *Must say turnigy marine to be a seaking.
                  * Also note the Venom Pro esc is also a seaking and the hobbywing box will work on it as well* (http://www.hobbyking.com/hobbyking/s...idProduct=7360 same as http://www.venom-group.com/itemdesc.asp?ic=1398)
                  These are Hifei esc's
                  http://www.hobbyking.com/hobbyking/s...dProduct=10626 same as http://www.offshoreelectrics.com/pro...=hef-sword-120
                  hobby wing box will not work
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • dano1
                    • Dec 2010
                    • 439
                    well it dont say marine.....and i think its fried anyways....i orderd a new one and a 180 amp for the geico and.........a pair of 60 amps for the kos....i hate that boat, one lost programing again. THANKS DALE ......AGAIN
