One sweet ride
  • bustitup
    • 3072
    One sweet ride
    http://cgi.ebay.com/Custom-Electric-...item20ae9429e1
    • 9481
    wow, if he sells it for that, I'm building 3 and selling them!
    • ozzie-crawl
      • Sep 2008
      • 2943
      he has taken out a 23cc motor and put in a fiegao 580l
      for that sort of $$$$ i would want at least a neu 1900zr
      • hide
        • Dec 2008
        • 188
        As nice as it looks that 150A ESC is not enough for it. I'd want a bigger motor too.
        • wakeboardfusion
          • 514
          Why would someone do all that work and put el chepo esc in there?
          • hide
            • Dec 2008
            • 188
            The ESC is actually pretty good, I have one in my Speed Car and it is very similar to the stuff Speed Passion sell. I'd want at least 200A in a 1/5 truck.
              • 9481
              not that I'm trying to sell this over priced electric buggy.
              that esc I think will take 1000 Amp spikes?
              • hide
                • Dec 2008
                • 188
                AFAIK a surge is usually only 75% of the cont. so the 1000A won't be used as the ESC would blow prior to that.
                • Diegoboy
                  • Mar 2007
                  • 7443
                  SPECIFICATION
                  •Continues Current: 150A
                  •Max Current: 1080A
                  •Input Power: 2-6s li-poly battery pack or 6-18s Ni-MH battery pack
                  •BEC: 5.75V/3A (Switch mode built-in BEC)
                  •Resistance: 0.0002 Ohm
                  •Motor Supported: Sensorless and sensored brushless motors
                  •Suitable Brushless Motor: 3.5T and > 3.5T
                  •Suitable Car: 1/5, 1/8 on-road or off-road cars / trucks for competitive race.
                  •Weight: 150g
                  •Dimensions: 68 x 55 x 45mm
                  Pulled from Here.
                    • 9481
                    you got the goods Diegoboy
                    maybe the cont. should be rated higher?
                    • hide
                      • Dec 2008
                      • 188
                      We shall see, I'm using one for speed runs in a 1/10 touring car. Its massive! Only on a 540 3.5T now but will be going with a 1/8 motor and 6S in the future so if it can handle that easily maybe.
                        • 9481
                        oh man, not an issue for that car..
                        I've seen these escs in 1/8th scale MT on 6s without issues
                        • ozzie-crawl
                          • Sep 2008
                          • 2943
                          if a neu 1900zr (direct zenoah replacment) was used you would probably get away with a 120a hv esc
                          • hide
                            • Dec 2008
                            • 188
                            This truck is way way bigger than a 1/8 MT. Far heavier too.
                              • 9481
                              Awesome, that was just my point to your post..
