aquacraft revolt
  • nitronuts
    • Feb 2012
    • 1152
    aquacraft revolt
    This has a new 150 amp esc 2-6s lipo also installed a lightly used fieago nemesis 10xL 1668 KV motor 3674 size this should be very fast with this set up.I did the same to a ul-1 and it flies.its in very good condition.and was just bench tested and works perfectly.I put a new 42mm prop on it from a traxass spartan so it should work be a good starting point as far as the prop goes.always try others to get the perfect setup.3/16th prop shaft.this will be at least 5 mph faster than the aquacraft set up.also removed teflon tubing to free up the flex shaft and this is much better.Also upgraded flex shaft installed
    You will need transmitter/receiver and batteries to be ready to run
    265.00 shipped firm to lower 48 u.s.
