Delta Force 16" RTR info on if the stock setup would work on a 4s ?
    • 4297
    Delta Force 16" RTR info on if the stock setup would work on a 4s ? https://forums.offshoreelectrics.com...lta-Force-RTR=
    Yes I know old post but looking for more info.
    Because I have this one,https://forums.offshoreelectrics.com...e-votex-16-rtr
    but do not know what the stock outrunner kv is and I do not know what the amp of the esc is ether.
    Been using 3s with a x632 prop and all is running cool with motor temps most of the time at 120f to 130f in hot summer 95f day with about a 5 minute run time.
    Specs,
    the boat comes w/ no literature. Just a folded 1/2 piece of paper that says to tighten the turn fins and how to tighten the set screw to lock on the rudder.
    Thats about it.
    Seeing that all vids on DF were on 3S, and around 2200mah I think, thats what I based my set up off. Could it take more and handle it? .
    Hull designed by Delta Force
    Material : Fiberglass (FRP)
    Weight : 280G (without Fitting)
    Hull Size : 584 (L) x 170 (W) 100MM (H)
    Packing Size : 600 (L) x 250 (W) x 150mm (H)
    Total Weight : 1120g
    Parts Included:-
    ESC - 45A (With Watercooler)
    Motor - 2200KV Outrunner
    High Preformance Racing Motor Watercooler
    Angle Correctable CNC TurnFin
    CNC Rudder and Sevro
    Propeller Size : 430x1.4
    Wood Boat Stand Included
    3M Waterproof Tape
    Parts no Included:-
    Radio Control (Requied) 2 Channel
    Battery (Requied) 7.4 - 11.1V Li-po (min.1800MA)
    (T-Plug) or Ni-Hi battery 7.2V to 12V (min.1600MA)
    Thanks for any info.
