Dual/Twin Drive Delta Force 33 (2x540L)
  • obrien008
    replied
    No I dont actually plan on running diff size props but it would be fun to experiment with and maybe lowering the outside strut if I were to try some oval stuff.
    I have plenty of play in the depth I can put the props at, if I were to run submerged props what size props and what motor would you use?
    Pics coming up now once I figure the posting out
    Leave a comment:
    replied
    Originally posted by Rumdog View Post
    You will need to run sub-surface drives or outboards. Twin surface drives will not work.
    plus same size props
    Leave a comment:
  • Rumdog
    replied
    Leave a comment:
    replied
    Originally posted by obrien008 View Post
    Thanks for the feedback. I know that turning will be a problem but im not looking to use it as an oval racer or anything like that. I really just wanted counter rotating props so it will be more stable than some of my other monos. I also thought that i could raise and lower the struts some or even use a bigger prop on the outside in order to keep it in a bit more. Thats something I can mess around with once I get bored with the straight runs.
    What do you think about 540Ls on 4S???
    making a mono stable has to do with setup, not running twins to get the job done
    also running two different size props will never work right
    twin outdrives will work much better than twin indrives, but this could be loads of fun
    Leave a comment:
    replied
    Use twin rudders, Speedmaster long .21 mono tapered rudders. Turn on a dime.
    twin rudders are not needed and could be just a waste on a 33
    rudder with turn fins in the better way to go
    Leave a comment:
  • obrien008
    replied
    Well I already got the rudder mounted and that thing is huge, maybe even too big. As far as the motors go those typhoons look awesome and ya for 25 dollars they look like they will put off as many watts as the fiegos. The only thing is I am worried about the heat on those things. Is a watercooled mount enough to keep them at a safe temperature?
    Leave a comment:
    replied
    Leave a comment:
    replied
    ... and twin Super Simple esc's 100 amp versions.
    2 motors= $50
    2 esc's = $50
    Some Turnigy packs and you are laughing for under $300 power package.
    Nice and fast and cheap. :D
    Leave a comment:
    replied
    I think you should use twin Turnigy Typhoon 500 motors. For $25 each, they can't be beat.
    They will be sold out by Monday I bet.
    Leave a comment:
  • obrien008
    replied
    Leave a comment:
  • Rumdog
    replied
    The reason you haven't seen many dual drive monos such as DF hulls if because it doesn't work well. The problem, being the surface drive. As soon as the hull banks into a corner, the outside prop will surface, therefore having 0 efficiency.
    Leave a comment:
  • obrien008
    started a topic Dual/Twin Drive Delta Force 33 (2x540L)
    Ive been wanting to build a dual drive mono for some time now. I have not seen many around and was looking to do something a bit different. Ive decided to use a DF 33'' hull and will prob use 2 Fiego 540 11L's on 4S with counter rotating props. I will be using a Speed Master Rudder with 5" of set back and 2 Fueller struts with 3.25" of set back. Im not sure how all of this long hardware will effect how it runs but I am really liking how it looks so far plus im looking for something different.
    So Far I have:
    DF 33" Hull
    Speedmaster Rudder
    Fueller Struts
    Motor Mounts
    Trim Tabs
    Flex Shaft/Couplers
    So basically everything I need to get it ready to go other then the escs/motors/batts and some turn fins which I should have in the next few weeks
    Anyways if anyone has any experience with a dual drive mono or any tips/suggestions I would really appreciate it.
    Im working on mounting the rudder and struts and I will get the pics posted in the next day or two.
