F1h2o
  • Bande1
    replied
    That is a beauty! I fell in love with my old tunnel hull someone at my club gave me. I de-converted it from electric to nitro and man it has opened my eyes to how fun petrol is. You should look into a used K&B for that bad boy!
    Leave a comment:
  • Returntohome
    replied
    Leave a comment:
  • Returntohome
    replied
    F1h2o Italian job!
    Photo 1, a short length of 1.6mm wire, no bends needed, gives steering servo an easy job.
    Photo 2, Seems very close without a wire extension, maybe I could make those brass tube adapters in the photo an inch longer and solder the esc wires directly to them. Covered in heatshrink of course.
    Printer....I watched a utube video of how to clean out the hot end on my anycubic vyper, excellent, so will try it, it's been used for over a year so guess it's overdue for a service. I can recommend this printer, which I did to club mate Philip, he loves it too.
    Leave a comment:
  • Returntohome
    replied
    F1h2o Italian job
    It's been a difficult day, notice the red wing mirror is now white. The red didn't dry, so spent an hour rubbing them down , repainting, white probably looks better anyway. In between that I have been trying to fix the printer, at one time it just kept switching off . Anyway I've ordered a new hot end from aliexpress so will have to do without for a while, hope that sorts it.
    Leave a comment:
  • Returntohome
    replied
    Pleased that went well, getting all these on without messing any up is quite a challenge. Wing mirrors next.
    Leave a comment:
  • Returntohome
    replied
    F1h2o
    Boat club yesterday morning, then try to sort printer it's thrown a massive wobbly. After much head scratching I think it was in need of a new nozzle, which seems to have done the trick. Then I finished the wrap, with teatime upon me I started masking off the windows. I had to be called down for dinner, whoops.
    I didn't want to leave the tapes on overnight so went back to finish it, only a short drying time and peeled off the tapes, wow it brought it to life, pleased that went well.
    Leave a comment:
  • RandyatBBY
    replied
    Well it looks like you are having fun and that is what it is all about.
    Leave a comment:
  • Returntohome
    replied
    I do have ways of raising the engine, but so far I've found my props suck air in and loose traction if too near the surface. Which is why I added the hydrofoil cum anti ventilation plate. However I could produce a special short shaft version of my outboard just for this model, the mid section being 20 to 25mm shorter. Instead of filling with oil I would pack it with high quality grease, sealed for life, this would help me make it shorter. I think testing on the water will show which is the best way. I might make a battery bay cover just for testing with a gps window and a watt meter.
    What will be the effect of it being too low, is it just loss of speed, or will it try and take off, ie poor handling?
    Leave a comment:
  • NativePaul
    replied
    Nice, could you make one with a shorter leg? For best results the botom of the prop should be level with or slightly above the bottom of the sponsons. you couls always raise up the one you have, but it looks like that would put the cowling well above the top of the cabin and look a bit funny.
    Leave a comment:
  • Returntohome
    replied
    Thanks, I designed and built it from scratch using a small lathe and 3d printer. I now have 3 prop outboards and 2 jet drive outboards also designed by me. Let me find a you tube link.
    Leave a comment:
  • RandyatBBY
    replied
    wow that is a neat looking Out Board motor. do you have a link to it?
    Leave a comment:
  • Returntohome
    replied
    Progress is slow but sure
    Leave a comment:
  • Returntohome
    started a topic F1h2o
    F1h2o
    My F1 project is taking shape, although it's a big model it's still tight in the fuselage, so I've printed a tower so everything fits in the rear end.
